Select multiple Layouts?
In AutoCAD I was able to select multiple layouts by holding the shift or control keys, but it doesn't appear to work the same with V16, at least not by default; is there a setting I need to change, or other method?
  • You can select multiple layouts from the 'Page setups' section of the Drawing Explorer (Ctrl + 2).
    Regards,
    Jason Bourhill
    Regards,
    Jason Bourhill
    I see, hopefully I can remember that. A few more steps than in AutoCAD, guess that could be another SR...
