esnaps unreliable
Im having serious problems with esnaps in V16. 2 Machines same issue. Is anyone alse experiencing this? All drawings. make some squares
set endpoint snap , choose copy, pick a Point in one corner of a Square.
Now zoom slightly with the mouseweel an move the cursor around and try to snap to items without picking them. Within a few seconds it starts to disappear. Even when Im close sometimes it says endpoint but does not show properly. Sometimes it snaps correct sometimes not .
Watch my video
https://www.dropbox.com/s/6902mj3wprgf3yg/SNAP1.mp4?dl=0
or this
https://apia.wd2go.com/api/1.0/rest/device_redirect?device_user_id=14373851&device_uri=%2Fapi%2F1.0%2Frest%2Ffile_contents%2FPublic%2FShared%2520Videos%2FScreen%252003-18-2016%252011-38-34.avi%3Fdevice_user_id%3D14373851%26request_auth_code%3Dd45182f597927f01836e5d4c2da06c2eb615f5fe0a24c90a6071a44b81d37101
I have posted an SR but wonder how no one has noticed.
Patrik
  • Same thing here except I use V15. Using endpoint snaps sometimes it'll indicate being picked sometimes not in a "crowded area". Didn't notice this being an issue in V13.
  • I get that in v15 - the esnap marker sometimes partly disappears.
    I think I only started noticing it when I turned on Selection Preview Display. I used to have it turned off.
  • Never saw this in V13 and dint think Ive seen it in V15. I only started to try using 16 but had to revert back.
