draw a parable
Hi everybody,
I need to draw a parable. Somebody know how to do it with spline? It's possible?
I have changed the configuration for spline to cuadratic, but when I draw it, if I see his property, I always get grade 3 (cubic)
Help, please....
Thank you very much
Help, please....
Thank you very much
0
One way to obtain a parabola (it indeed results in a spline) is using a cone and a section.
* Draw a cone
* Draw a slant section through the cone (one that does not result in a circle or triangle)
* This results in a region, which you can explode in a spline and a line. The spline is a parabola (well, a clipped finite version of course).
Of course you can directly manipulate a spline, but this way can be instructive.
I think all that it takes is a spline with 3 control points, and the middle control point has to be on the perpendicular bisector of the other two control points.
Regards
Tijs0
