add ggrs87 / Greek Grid
in Other
can you add this gis coordinate system ?? https://epsg.io/2100
PROJCS["GGRS87 / Greek Grid",
GEOGCS["GGRS87",
DATUM["Greek_Geodetic_Reference_System_1987",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[-199.87,74.79,246.62,0,0,0,0],
AUTHORITY["EPSG","6121"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4121"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",24],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","2100"]]
thank you very much!!!
0
Hello,
this is the user forum, for user-to-user communication.
For requests to Bricsys development, please file a support request. Thanks!0 -
ok i downloaded bricscad trial to test the ggrs87 / Greek Grid and it exists! but when i tried to use it in wms server and load from this http://gis.ktimanet.gr/wms/wmsopen/wmsserver.aspx the maps arent loaded!!you know geolocation command and mapconnect!! can you do something about that? thanks!!
brics3.png0
