16.2.05 Publish generate new instance of BricsCAD
I've noticed that when using the publish command it will open another instance of BricsCAD during the creation of the PDF's and close when it's done. Is there a setting that will turn this function off?
  • Dear Rob
    The 'Publish in background' option of the Publish command controls whether the command is executed in the current BricsCAD session or not. Publishing in the background allows to continue working in the current session if a lot of layouts need to be printed. However, the background session should remain invisible, which seems not to be the case in the current version.
