Ortho not working in 16.2.08
Ortho is not working in v16.2.08 when dynamic input is enabled. Lines are drawn toward the cursor ignoring the displayed angle. If I tab to the angle and set it to 0, 90,180, or 270 the lines are drawn as expected. If I turn dynamic input off lines are drawn as expected.
0
I don't get this issue. Have your tried using a new profile? I assume OSNAPs aren't responsible.
Regards,Jason Bourhill
0 -
I restarted BricsCAD, nothing else and everything is working as expected.0
oops, I gave up too soon. This is occurring on multiple PCs. I've attached a video demonstrating the issue.0
Since updating to 16.2.08 I'm having the same issue.0
Hi Donald,
Your video clearly outlines the issue. If you haven't already done so I recommend that you raise an SR including your video.
0
