STLOUT
The STLOUT command in BricsCAD may not behave exactly the same as AutoCAD. When I view the BricsCAD generated .stl file in a STL viewer, there are artifacts visible. However, when AutoCAD generates the .stl file, there are no artifacts. The same parameters were used i.e. FACETRES = 10.
The 3D file was created entirely in BricsCAD. STLOUT from BricsCAD creates artifacts. STLOUT from AutoCAD creates no artifacts.
