missing search path
 Hello
I've just upgraded do V16, installed it, and it is not working properly:
support files searth path is missing, and the path only shows the letters "dt"  (see image attached)
I've already unistalled my previous version (v11), tried a fresh install and still doesn't work.
What is wrong?
Thanks for any help.
nuno
from portugal
  •  I've just solved this issue.
    I just created another profile and it works fine.
     I guess the problem must have been a reminiscent older profile from V11.
    This topic may be deleted
    nuno
