BricsCad quits when closing a single drawing
Often, when I go to close a single drawing I'm done using, BricsCad unexpectedly quits entirely, closing all drawings.  This has resulted in me losing information multiple times.  I try to remember this and save before closing anything, but that should not be necessary.  Has this been a problem for other users?  Is there any solution?
  • Hello William,
    Do you still experience crashes on quit in the latest V16.2.10 version?
    A few instabilities on closing documents have been fixed.
    This type of error is hard to reproduce.
    Please enter a support request, and attach an error log if you have one.
    You can find back past error logs in the Console app.
    To avoid losing work due to instability, have a look at the SAVEFILEPATH and SAVETIME variables.
    Kind Regards
    Tijs
