dimensioning problems: arrow heads & leader behind solid
It seems that I have specified Closed Filled arrow heads. But, I am getting slash like tick marks. Any suggestions on how to get the arrow heads I want?
"wrong arrow heads.png"
Also, I try to select a face on one side of a solid. Then, the dimension appears on the other side of the solid. Any idea how or where to select?
"hidden leader.png"
I'm in a paper space layout, using 'Modeling' visual style, 3D Modeling work space. Bricscad Platinum, 16.2.09, Windows 7.
"hidden leader.png"
0
OK, about the 'hieedn leader', this was because of a poor UCS choice. The dimension was created on the UCS X Y plane, which was behind the object. This UCS on top of the object works.
"better UCS.png"
But, I still get the un-wanted type of arrow head.
better UCS.png0 -
You probably have a dimstyle override.
You can use the -DIMSTYLE command to check this (note the '-') and then use the _Restore option of that command.
Making the active dimstyle, or any other style, current in the _EXPDIMSTYLES panel will also get rid of overrides.0 -
Thanks for the suggestion Roy. Unfortunately it did no work. Perhaps I had already saved some overrides to the style "Standard".
What did work was to create a new drawing. From there I copied dimstyle "Standard". I pasted it do my existing drawing as "Standard1".
I think the difference is DIMSAH variable. Not sure.
DIMSAH On Controls if DIMBLK or DIMBLK1 and DIMBLK2 are used for arrowheads
That is displayed with -dimstyle, then st for "status"
I did not find where the DIMBLK blocks are, or how to view them. Sort of ran out of time.
Here is a comparison of Standard and Standard1 dimstyles: "dim style comparison.png" (big bitmap, lots of scrolling to see it)
dim style comparison.png0 -
I don't know what method you used to copy dimension settings across, but you can do this from the drawing explorer. If you paste a style that already exists BricsCAD will give you the option to overwrite, which would also automatically update all the affected objects
https://bricsys.tv/m/?copying-definitions-between-open-drawings-m233
Regards,Jason Bourhill
0 -
@ Eric:
After removing the active overrides the dimensions that have been created with these overrides do not automatically change. You need to use the _Apply option of the _-DIMSTYLE command (there is a button for this in the 'Dimensions' toolbar).
When discussing such issues it is usually more helpful to provide a drawing file instead of images.0
