show decimal numbers in properties toolbar
I'm getting a display of 1/8" for text height in the properties toolbar. I would prefer to see something like .125, because 1/8 is not precise enough. I was thinking this might be a workspace customization, but can't figure it out. Any suggestions?
"fractions in property toolbar.png"
0
0
Yes! Thank you Jason.
Typing UNITS brings up settings at Drawing/Drafting/Drawing units. Then, expanding the Linear Units item showed Architectural. I changed this to Decimal. Problem solved.
0
