show decimal numbers in properties toolbar
I'm getting a display of 1/8" for text height in the properties toolbar.  I would prefer to see something like .125, because 1/8 is not precise enough.  I was thinking this might be a workspace customization, but can't figure it out.  Any suggestions?
"fractions in property toolbar.png"
  • Take a look at UNITS.
    Regards,
    Jason Bourhill
  • Yes!  Thank you Jason.
    Typing UNITS brings up settings at Drawing/Drafting/Drawing units.  Then, expanding the Linear Units item showed Architectural.  I changed this to Decimal.  Problem solved.
    "SettingsDrawingDraftingDU_LU(3).png"
