Creating attributed polyline for wire and wire labels?
Hello,
I am wondering if there is functionality in BricsCAD to create a polyline with attributed text similar to that in the image attached below. As you can see I would like to create a wire with configurable wire labels at each end. I would like the text to be attributed so that it can be extracted from the drawings to ensure wire tags are not duplicated throughout the drawing. I would also like to mask underneath the attributes but that is a separate issue.
Could dynamic blocks accomplish this? Is a LISP routine required?
I have found a way of doing this by using a multileader with a block attached at the end, however I'm only able to attach the block to a single end of the MLeader and this doesn't seem to be a very sleek solution.
I am on BricsCAD Classic Version 15.3.09
Thanks,
  • Hi Kieran,
    If you are willing to consider using a third-party tool, our CADPower may have a solution for your requirements.
    First, to attach attributes to any CAD entity, you can use XDATA, which is a standard CAD features. This is easily done using the CP_DATAMAN command in CADPower using user-created INI files for defining the structure.
    Next, you can create the CP_OD_XD_LABEL tool to create labels from your attributes and place them along-side your entities.
    This tool may or may not be exactly what you want to see but I am keen to hear from you and fine-tune the tool to do something that is closer to what you need.
    CADPower users use this tool a lot to create more meaningful and intelligent data driven entities in their .dwg platform.
    Best Regards
    Rakesh Rao
    Smarter .dwg CAD
  • Hi
    its not quiet your complete whish, but i have an Tool, whitch writes into the linetype the Layername where it's put on.
    You can use this Tool. With some changes you can do your suggestion.
    [code](defun C:LTYPES->Layer (/ DNAME DATEI LAYER LAYERNAME LT LTPS OLDCMD Block ITEM LAYOUT)
      (vl-load-com)
      (setq DNAME (strcat (getvar "SAVEFILEPATH") "Temp.lin"))
      (if (setq DATEI (open DNAME "w"))
        (progn
          (While (setq LAYER (tblnext "LAYER" (null LAYER)))
            (setq LAYERNAME (cdr (assoc 2 LAYER)))
            (setq LTPS (cons LAYERNAME LTPS))
            (princ (strcat "*" LAYERNAME ",-" LAYERNAME "-\n") DATEI)
            (princ (strcat "A,3,-1,[\""
                           LAYERNAME
                           (getvar "TEXTSTYLE")
                           ",S="
                           (rtos (getvar "TEXTSIZE"))
                           ",R=0.0,X=-";0.1,"
                           (rtos (/(getvar "TEXTSIZE")2))
                           ",Y=-"
                           (if (> (strlen LAYERNAME) 1)
                             (itoa (fix(*(strlen LAYERNAME)(getvar "TEXTSIZE"))))
                             "2"
                             ) ;_ end of if
                           "\n"
                           ) ;_ end of strcat
                   DATEI
                   ) ;_ end of princ
            ) ;_ end of While
          (close DATEI)
          (setq OLDCMD (getvar "CMDECHO"))
          (setvar "CMDECHO" 0)
          (foreach LT LTPS
            (if (tblsearch "LTYPE" LT)
              (progn
                (command "_-linetype"
                         "_l"
                         LT
                         (findfile DNAME)
                         "_y"
                         ) ;_ end of command
                ) ;_ end of progn
              (progn
                         "_l"
                         LT
                         (findfile DNAME)
                         ) ;_ end of command
                ) ;_ end of progn
              ) ;_ end of if
            ) ;_ end of foreach
          (vl-file-delete (findfile DNAME))
          (setvar "CMDECHO" OLDCMD)
          ) ;_ end of progn
        ) ;_ end of if
      (vlax-for LAYOUT (vla-get-layouts
                         (vla-get-activedocument (vlax-get-acad-object))
                         ) ;_ end of vla-get-layouts
        (vlax-for ITEM (setq BLOCK (vla-get-Block LAYOUT))
          (vl-catch-all-error-p
            (vl-catch-all-apply
              'vla-put-Linetype
              (list ITEM
                    (vla-get-layer ITEM)
                    ) ;_ end of list
              ) ;_ end of vl-catch-all-apply
            ) ;_ end of vl-catch-all-error-p
          ) ;_ end of vlax-for
        (vlax-for BLOCK (vla-get-blocks
                          ) ;_ end of vla-get-blocks
          (vlax-for ITEM BLOCK
              (vl-catch-all-apply
                'vla-put-Linetype
                (list ITEM
                      ) ;_ end of list
      )[/code]
  • @ Martin:
    In BricsCAD there is no need to create a temporary .lin file. You can either entmake a linetype or use the appropriate vl* functions.
