Jig. Additional panel with keyWords.
Hi!
I'm trying to make a Jig.
When running the standard command, we can see an additional panel with key words.
In my Jig this panel does not appear.
How to display an additional panel with key words?
[code]PromptPointResult userFeedback = prompts.AcquirePoint("\nSpecify endpoint of arc or [Line/Undo]: ", "Line Undo");[/code]
0
For the prompts on the command line, set CMDECHO = On.
For the pop-up panel of options, set PROMPTMENU = 1 or higher (see Settings window).0
