Bug reports
Anyone else having trouble filing bug reports?  The drop-down for version (I think -- lower right box on the form) is not populated and the form will not send unless that box is filled in.  I can type into the box but all text I have tried is rejected as being invalid.  There is a problem printing from the version I downloaded earlier today -- all I get is blank sheets.
  •  Just checked and I get the same issue with the bug submit. Looks like a programming boo-boo. If a language other than English is selected then the combo box with the versions is populated and selectable. For English, the combo box list is blank.
    Bug report submitted for the bug report form.   ;-)
