Multileader
 Whenever I start a new file, I have to modify by MULTILEADERSTYLE the multileader that I prefer to use for the drawing.
Is there any way for my preferred multileader style to be retained as the preferred/standard multileader?
  • Hi Harvey,
    You can do this by creating a template. Once you have set up the MULTILEADERSTYLE they way that you want, use SAVEAS and from the 'Save as type:' drop down select 'Drawing Template (*.dwt)'. The template needs to be saved to the folder defined by 'TemplatePath', which you can find in SETTINGS. Once you have saved your template you can make it the default by going back to SETTINGS and setting BASEFILE to point to it.
    Regards,
    Jason Bourhill
    Jason , thanks for the info.
