Problem with path, regional characters/letters in folder/file name
in 3D Modeling
Hello,
I've problem with Polish regional characters/letters.
When I attach a image/xref everything is ok. But when I close my Bricscad and open saved .dwg file again, Bricscad changes letters in attach paths (img, dwg, pdf etc...).
For example attach path (when I open program again):
\\projekty\2016\\PRZYCHODZ¥CA\20160722_\Projekt techniczny - wewnêtrzna instalacja wod-kan i p.po¿\Projekt techniczny - wewnêtrzna instalacja wod-kan i p.po¿\19.tif
but should be:
\\projekty\2016\\PRZYCHODZĄCA\20160722_\Projekt techniczny - wewnĘtrzna instalacja wod-kan i p.poŻ\Projekt techniczny - wewnĘtrzna instalacja wod-kan i p.poŻ\19.tif
So proglam looses the path and shows me only frame in imageattach place, so everytime when I open my dwg, I've to change sign on my regional characters.
I know that simplest solution is to change folder/file names without regional signs, but this should be solved diferent.
My question:
How to solve this anyway?
Is there a solution for Bricscad that could keep my folder names?
I've Bricscad v15 64bit with Polish languagepack
thanks in advance
0
There is a similar post to yours on the Linux forum
https://forum.bricsys.com/discussion/30072
The workaround discussed there is to turn off MTFLAGS. I would think that making sure bit flag 4 isn't set for parallel loading of the drawing file.
I would suggest raising a support request on this if you haven't already done so.
Some other workarounds you could try:- Use relative paths as much as possible when attaching dependencies (Xrefs, Images, PDF).
- Try setting up a Project name and add the paths to your dependencies to that.
- Add the paths to your dependencies to the support file search path (SRCHPATH).
Regards,Jason Bourhill
Projects-Setup.jpg0 -
Unfortunatelly it does not work ;/ but thank you for reply.0
Could anybody tell me why it works not I have expected ;] ;/ ?I have Bricscar v15 64bit Polish language. Everything is made in Standard text style with Arial font.In dwg I have also problems with regional characters layerlist, patchs in that file...0
