V16 Lagging Problems
We just upgraded from v15 to v16 last week, and have noticed that v16 has considerable lagging issues when zooming in and out, base copying, and other commands. What has caused this problem, and is there a way to fix it? We are forced to use v15 until the problem is resolved.
  •  A new setting was introduced during V16, the ability to set anti-aliasing of the geometry on the screen; try setting the variable ANTIALIASSCREEN to 0, this will yield a slightly rougher display but will increase performance.
    Thanks Scott, that significantly significantly improved the performance.
