invisible drawings
 guys i dont know how to describe this problem... when i draw lines, polylines rectangles etc i get this picture in general, i cant see the lines between the nodes!!! can anyone helps? all were working ok before i use the bricscad bim!!! is there some setting that changed?
  •  nevermind the solution was to delete .bricscad file inside my home folder and reset my settings!!! oh dear!!!
