Auto stacking fractions
in Other
I need to have fractions auto-stack like AutoCAD does. Is it possible? Where can I find settings for this?
BricsCAD doesn't Autostack fractions as you type. You need to first type in what you want, select the text, then pick the stack button. Syntax for stacked text is:
- 1/2 for horizontal fractions.
- 1#2 for diagaonal fractions.
- 1^2 for stacking without a line. Useful for creating superscript and subscript text.
Once you have created a stacked fraction you can select it and by right clicking you can go to 'Stack Properties' where you can fine tune how your stacked text displays.Regards,Jason Bourhill -
Here is a lisp program that stacks MTEXT fractions. You can modify as you see fit...to include other items similar to fractions.
As you can see below it is limilted to 1/16" increments max. (but you could add more to the list)
You might want to remove the (princ N ) line and (princ.....SKIPPED)))) lines if you don't want all texts to print to console.
ddk
[code](defun c:STAKFRAC ()
(prompt "\nSelect Objects: (Select a window)")
(setq SS1 (ssget '((0 . "MTEXT"))))
(cond (SS1
(princ (sslength SS1))
(setq ALST
'(("15/16" "{\\H0.7x;\\A1;\\S15#16;}") ("13/16" "{\\H0.7x;\\A1;\\S13#16;}") ("11/16" "{\\H0.7x;\\A1;\\S11#16;}")
("9/16" "{\\H0.7x;\\A1;\\S9#16;}") ("7/16" "{\\H0.7x;\\A1;\\S7#16;}") ("5/16" "{\\H0.7x;\\A1;\\S5#16;}")
("3/16" "{\\H0.7x;\\A1;\\S3#16;}") ("1/16" "{\\H0.7x;\\A1;\\S1#16;}") ("7/8" "{\\H0.7x;\\A1;\\S7#8;}")
("5/8" "{\\H0.7x;\\A1;\\S5#8;}") ("3/8" "{\\H0.7x;\\A1;\\S3#8;}") ("1/8" "{\\H0.7x;\\A1;\\S1#8;}")
("3/4" "{\\H0.7x;\\A1;\\S3#4;}") ("1/4" "{\\H0.7x;\\A1;\\S1#4;}") ("1/2" "{\\H0.7x;\\A1;\\S1#2;}")))
(setq N 0)
(princ " Done")
(repeat (sslength SS1) ;Walk through text
(princ N)
(setq E1 (ssname SS1 N)
ET (cdr (assoc 0 (entget E1))))
(cond ((= ET "MTEXT") ;Check again
(cond ((assoc 3 (entget E1)) ; Toss paragraph
(princ " Mtext Paragraph Skipped\n"))
((and (assoc 1 (entget E1)) ;Has text string
(= (cdr (assoc 67 (entget E1))) 0)) ;And is in Model Space
(setq TXT (strcase (cdr (assoc 1 (entget E1)))))
(foreach TX ALST ;Walk through fraction list
(cond ((wcmatch (strcase TXT)(strcase (strcat "*" (car TX) "*"))) ;fraction found
(princ (strcat " " (cdr (assoc 1 (entget E1))) " Found\n"))
(command "ZOOM" "C" (cdr (assoc 10 (entget E1))) 20.0)
(redraw E1 3)
(prompt "\n(E)dit (N)ext")
(setq INP (grread) IN (car INP))
(if (= IN 2)(setq YN (strcase (chr (cadr INP)))))
(cond ((= YN "E")
(setq STRL (strlen (car TX)) ;String Length of fraction
N0 (vl-string-search (car TX) TXT) ;Location of fraction
STR1 (substr TXT 1 N0)) ;Text Before
(if (= (substr STR1 N0) " ")(setq STR1 (substr STR1 1 (1- N0)))) ;Strip trailing blank
(setq STR2 (substr TXT (+ N0 STRL 1)) ;Text After
STR1 (strcat STR1 (cadr TX) STR2) ;replacement String
EL (entget E1)
EL (subst (cons 1 STR1)(assoc 1 EL) EL)) ;subtitute in entity
(entmod EL))))))
(princ (strcat " " (cdr (assoc 1 (entget E1))) " Skipped\n"))))) ;Mtext no fractions
(t
(princ (strcat " " (cdr (assoc 1 (entget E1))) " Odd Text Skipped\n")))) ; Wierd stuff
(setq N (1+ N))))
(t
(princ " No Text Found")))
(princ "\nDone")(princ))
[/code]
Howdy, Stranger!
