V17 layer invert
 Hi,
Ok, the layer "invert filter" on the layer manager is not working. I use this to filter out the xref layers. Any workarounds or variables that I should know about?
Many thanks
  • I think this is a bug. You should send in a Support Request.
    Note: You can create your own "NoXref" filter.
    Just use this for the Layer Name field:
