Lengthen bug?
I am trying to lengthen an oblique line (i.e. a line that's not horizontal or vertical), using the Increment option. The line seems to lengthen by a smaller distance than the increment I choose. Am I doing something wrong or is this a bug?
0
Please check whether the line is perfectly horizontal. If not it seems as if the the added distance is shorter than you expected.0
Hello,I am using the Distance command to check the final length of the line and it is shorter than expected.This does not happen if the line I lengthen is vertical or horizontal, only when the line is at an angle.0
For clarity: when I write 'horizontal' I mean endpoints at the same Z-level.0
Oh my god, you are right! I feel so ashamed now. How can I delete this silly post?0
