Hide certain layers in viewport
how can I hide certain layers just in a specific viewport?
0
Double click in the VP to activate it.
Start the _Layer command.
Look for the 'VP Freeze' column.
Alternatively you can use the _VpLayer command.0 -
Rather than hunt for the layer, I first select an object on that layer. Then, that layer will be highlighted on the layer pull-down list. Then, you can click the icon to freeze that layer in just that viewport.-joe0
