Doctabs doesn't work on Bricscad Pro v12.2.4 64 bit?!
It doesn't work! The tab bar doesn't show up at all.
I can have a dozen or more files open at once on two instances of Bricscad on my two monitors.
Doctabs is essential, and should be a core part of Bricscad IMHO.
I understand that 32 bit applications have to be recompiled.
I see that Doslib has been. Thanks!
Anybody have any idea how long it will be?
Hi, I have uploaded a 64 bit version for you to try. Let me know how it works for you
www.cadext.com/downloads/DocTabs64_EN.exe
Cheers : )
0 -
Great, it works. Thank you!0
Hey Daniel: You are appreciated.0
AW.some!
That was much faster than I'd hoped.
Marvelous! I simply can't get along without it.
Thanks!0 -
Hello, where you downloaded the Bricscad Pro v12.2.4 64-bit?
Thanks for the reply.0 -
64bit first available in V13.2.
You can DL 32bit Version 12.2.18-1 from download page (under "Old Releases")
0 -
Daniel- I too, like everyone else here love this add-on. I just installed Brics 13, do you have an update? I stayed 32bit,
because I need VBA.
Thanks!
0 -
v 1.0.3.14 (working here on v13 32bit) available for DL in Applications Store / Free Tools.0
Thanks Robt-
How did youn get it to install to 13? When I run the installer it only sees installations of 11 and 12. My 13 doesn't show
in the list.
0 -
Curious. Install here offers Bricscad version options. I simply checked off box for v13.0
My installer shows version 1.0.3.14. Same as yours?
For some reason I am unable to download a new copy from the applications store - nothing happens when I hit the download button.
0 -
Yup 1.0.3.14. Again curious. I can DL no problem.
Did you check the "I agree" box on the TOS?
0 -
Got it- for some reason it wouldn't activate the download earlier, this time it worked, and V13 showed up as an option.
Thanks for the help!
0 -
Hi, would you still have DocTabs64_EN.exe for BricsCAD V14 x64 ?
It's not in freetools anymore!
Thanks.Hi, I have uploaded a 64 bit version for you to try. Let me know how it works for you
Cheers : )
0
