Sheet Sets assigned to current job loading from templates
 I don't know if this is possible, but we work with layouts in one file, and have worked out how to create sheet sets to reference these views.
However, I was wandering if I was to load a drawing from a template, it would load up a sheet set that referenced this new drawing that was created and it's views.
  • I believe in this scenario you would copy the drawings (in .dwg form) + the sheet set to another folder, then start from there. I believe Sheet sets are supposed to use relative referencing as the default, so will find the drawings under the new folder as opposed to the originals.
    Regards,
    Jason Bourhill
