laymch ExpressTools PickAdd?
Is laymch ignoring PickAdd? PickAdd set to 1
In ACAD2006 I pick the item to be changed then pick the button for laymch.
The routine asks for the pick of the layer to match.
Command: laymch
1 found.
Select object on destination layer or [Type-it]:
One object changed to layer zDtl Dim.
In BC17
: laymch
Select objects to be changed: [color=red]<-- ignores my pre-selected object[color=black]<br>Select entities:
Entities in set: 1
Select entities:
1 found.
One object changed to layer zDtl GenNotes.
Command: laymch
1 found.
In BC17
: laymch
Entities in set: 1
Select entities:
1 found.
0
BTW why does it take a minute & 20 seconds to post a new subject after you hit Reply?0
Well the reply only took a minute and six seconds.
Someone needs to fix that. Any mods around?0 -
Dear Charles,
probably you mean PICKFIRST - that one controls whether "pre-selected" entities can be used by commands ...
Nevertheless, even that is not a guarantee that every command will effectively use that "picked-first" selectionset.
many greetings !0 -
LAYMCH is an Express Tool command. As far as I can see it isn't included natively with BricsCAD. Some express tools such as, Overkill, and TXTEXP are included. I assume you are using the BricsCAD Express Tools, which includes LAYMCH, and indeed ignores any pre-selection. You would need to ask Martin (CADwiesel) why the command behaves like this.
The attached LISP will do much the same thing. If you pick in a blank space instead of an object it will bring up a dialogue which you can select from. Old routine, pre-dates toolbars with pulldowns and express tools, but still works :-)
BTW I have the same issue with posting times. The forums haven't seen much love in a long time and lack much of the functionality that you might see on sites like the swamp. :-(
Regards,Jason Bourhill
0 -
CAB,
This site has always been a bit slow.
You can find LAYMCH.LSP in clear text at http://www.eng-tips.com/viewthread.cfm?qid=24194. You may have to code around the error handler or find a copy. It is in AC_BONUS.LSP. Both files are from 1997 and are for R14. Both files also have a "free to use as long as you keep the header" statement.0 -
Thanks for the feedback. Yes I know Express tools are not an inaugural part of BricsCAD. Just thought I'd bring it up her to see is anyone else had the sane issue.
I did fashion my own fix.
[code];;; Change Objects layer to selected entity.
;;; CAB @ TheSwamp.org 12/20/16
(defun c:layerchange (/ *error* ss ent en el lay)
;; error function & Routine Exit
(defun *error* (msg)
(if (not (member msg '("console break" "Function cancelled" "quit / exit abort" "")))
(princ (strcat "\nError: " msg))
(princ)
(if
(and
(or (setq ss (cadr (ssgetfirst)))
(or (prompt "\nSelect objects to change layer.") (setq ss (ssget)))
(setq en (car (entsel "\nSelect object for layer to match.")))
) ; and
(progn
(setq lay (assoc 8 (entget en)))
(setq i -1)
(while (setq en (ssname ss (setq i (1+ i))))
(setq lst (entget en))
(entmod (subst lay (assoc 8 lst) lst))
(sssetfirst nil)
) ; endif
(*error* "")
(princ)
) ; end defun[/code]0 -
About the slowness of the Forum:
Refreshing the page after posting has become very, very, very slow somewhere this year.
I no longer wait for this and just close the page after a couple of seconds. If you do this your messages will post just fine. So I do not understand the reason for the delay.0
