Visual Studio and BricsCAD type library
 Hi,
I would like to develop an application for BricsCAD using Visual Studio and COM.
I have install BricsCAD V17 (trial edition).
My problem is that the BricsCad type library, is not appearing at the reference tab of my project.
It seems that it hasn’t been register on my computer.
Does someone has any suggestion what to do?
  • Hi Dimitris,
    You need to run BricsCAD one time 'as Administrator' in order to register COM.
    Regards
  • Alternatively, you can run
    "regsvr32 axvricscadapp1.dll"
    to register the COM server ...
    Please note, that BricsCAD allows to install the x86 version under x64 Windows - and BricsCAD x86 and x64 use same-named, but binary different TypeLibs.
    many greetings !
