Refedit nested blocks jumping like Autocad
I seem to remember, that in Autocad you have been able to double click on another block entity from inside a block (nested or not) and it jumps to it?
I cant seem to do it Bricscad. You always have to close the reference, double click on the nested object, select the nesting level and go inside again.
Is there a Way?
cheers
Is there a Way?
cheers
0
also:the cartouche of the drawing when this contains attributes, Bricscad can not edit the block cause it will always jump to theattribute texts.0
This is normal behaviour and is the same in autocad. You have to open attribute blocks with _refedit.0
