V17 delay in undo command?
Anyone but me noticed a long delay in the UNDO command (CTRL-Z)? Create a very simple array (two entities), and it takes about 20 seconds to "UNDO". Any idea on how to fix it?
  • I just did a quick test here arraying a circle, and UNDO was instantaneous. Do you have any plug-in code running (especially code that uses reactors)? If so, you might test without the plug-in loaded to see if anything changes.
    Regards
  • Owen,
    Thanks for your reply.  No, no plugin code.  And this is a new PC and new installation.
  • Dear Jim,
    I also verified arraying few LINEs - undo was without any significant delay ...
    other options :
    do oyu have an active AntiVirus software running ? Maybe disabling it temporarily to see whether that intercepts ?
    many greetings !
  • Torsten,
    Thanks for your reply.  No way to disable antivirus... Our IT manager has strict control.   The problem doesn't seem so bad right now anyway.
