Change Text Case
Does Bricscad have a command to allow a user to toggle text case between LOWERCASE, UPPERCASE, and TITLECASE?
New user, first day so sorry if I am missing something obvious. Thanks for any help.
0
Assuming that you are using MTEXT then it's available from the menu that opens when you create and edit the text.
Regards,Jason Bourhill
0 -
Thanks for the response, I see the options for all uppercase, or all lowercase, but no option for title case, where the first letter of each word is capitalized. Any other suggestions?0
Expresstools -> tcase0
Dear Guys,
Yet another option (tool) to handle case management is from CADPower.
http://www.4d-technologies.com/cadpower/manual/text_tools.htm#CHCASE
In addition to Upper, Lower and Title case, The CP_CHCASE command also does word replacement using translation dictionaries
Best Regards
Rakesh Rao
Smarter .dwg0
