Help with BIM
Hello,
is there a way to change the units of the composition walls and blocks (ie windows) from the default setting to meters without having to change each component?
Thanks
Daniel
Thanks
Daniel
Bonjour,
I do have the same question.
Thanks on forward
Yes, Just change section plane settings/ intersection fill / hatch scale from 10 to 0.01 and tada! Problem solved
Dont't forget to scale callout block section on their drawing by 0.001 to make them appear correctly.
Howdy, Stranger!
