Help! - papaer space / layout flipped 90 degrees
OK it was all going so well.......
layout1 seems to have flipped onto a different axis. The a little symbol bottom right of the view port that was showing an icon for a sheet of paper with a w on it and a couple of line. Now I have got a horizontal L with a X at the end.
No idea how I have done this or how to get back to an orientation I can continue with. but I still see the drawing as it was but if I try and add a dimension its like I am looking at the edge of the page.
If you type UCSW, it should come good - the UCS had been changed.
0 -
That didn't turn out as I typed it, try "UCS" return "W" return
0 -
UCS and Enter (Return) twice does restore the World UCS.
0 -
Thanks Gents,
WCS restored can continue to work of the layout know. You prompt advice is greatly appreciated.
AK
0
