Marking object Elprocad
When I select objects, the entire square is not drawn, but only a small square, 3-4 cm from the one I draw. For example, if I mark 5-9cm, only 2-4cm may appear on the screen, so I have no idea what I Actually marks. Anyone who knows was the setting for it is?
Command or what?
Thanks!
Maybe you should read help for select.
Howdy, Stranger!
