ADOLISP in Briccad for MDB files
there is a way to read/write .mdb Access files in Bricscad via LISP ???
There is something like ADOLISP in Briccad ?
Thanks in advance :-)
0
Hi Dom,
it should be possible to access the MS Access files via COM interface, provided by the Odbc/Ado drivers ...
Have you contacted the author of ADOLISP whether it runs on BricsCAD ?I slightly remember to have seen that tool years ago, and from what I recall, it was plain Lisp, so it should work with BricsCAD as well.
many greetings !
0 -
Hi Dom,
i use the ADOLISP library frequently and works with BC16 and BC17 without any problems.
Just download it from http://acad.fleming-group.com/Download.html
You can read and write .mdb Access files !
Regards
Konstantin0
