MultiLeader issue
in 2D Drafting
Hi,
I have found a minor issue in terms of AutoCAD <-> BricsCAD synchronization (since some of our branches are working on both programs).
When I copy and edit in BricsCAD a Multileader created in Autocad and save a file, then open it in AutoCAD the multileader line breaks as following:
I have to manually amend the text field and the line is back to normal.
It is a small thing but sometimes time consuming and irritating.
Cheers,
Jan
0
Hello Jan,
this is the BricsCAD user forum, for peer-to-peer communication between BricsCAD users.
If your intention is to report an issue to the BricsCAD development team, please file a support request, see https://www.bricsys.com/en_INTL/support/#4
0 -
0
Submitted, possibly one day someone will have a look
Cheers0
