MultiLeader issue
Hi,
I have found a minor issue in terms of AutoCAD <-> BricsCAD synchronization (since some of our branches are working on both programs).
When I copy and edit in BricsCAD a Multileader created in Autocad and save a file, then open it in AutoCAD the multileader line breaks as following:
I have to manually amend the text field and the line is back to normal.
It is a small thing but sometimes time consuming and irritating.
Cheers,
Jan
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
