mouse right click as "enter key"
mouse right click as "enter key" for quick drafting
Go to OPTIONS. Search for SHORTCUTMENU. There are many different ways to configure the mouse behavior.
Simply setting SHORTCUTMENU to 0 will give you right click as enter, but that may not work for other scenarios depending on how you like to work.
0 -
thanks
0 -
TIP: To enjoy the best of two worlds, shortcutmenus and the Quad, I'd recommend to set SHORTCUTMENU = 18 (Edit mode + shortcutmenu when the right mouse button is held down longer) and QUADDISPLAY = 5 (Quad on hovering + Quad on right click). You can then repeat the most recently used command on right click by helding down the right mouse button a little bit longer. When a selection set is present this procedure displays the Edit shortcutmenu on a long right click, while a short right click displays the Quad. Please notice that with these settings most recently used commands are also available in the Quad on a right click when the cursor is not over an entity.
0
