Printing black boxes
Hello,
Sometimes if I try to print a drawing it creates random black boxes in the print:
This only happens on 32 bit PCs, I never encountered this issue with 64 bit. This also happens if I create a PDF instead of a real print. Also it happens not with every drawing, only with some (I can’t even say that bigger drawings create this issue). But if I have such a drawing I can recreate it on other PCs (only 32 bit, 64 bit works fine). I cannot describe it better and googleing wasn’t helping me either (maybe the wrong keywords, but then I don’t know the right).
Does anyone have encountered the same problem or even better, has a solution?
Best regards
Edit: The print preview has no black boxes and is "correct".
Could it be related to the 32-bit drivers for the printer?
0 -
@Cyberdyne_T800 said:
Could it be related to the 32-bit drivers for the printer?I am not sure, but I don't think so, because I have the problem with every printer so far.
0
