Better filter mechanism
Hi,
A week ago i found a really cool cheap tool for filtering all kinds of stuff.
Escepically area, volume and z values is most welcome and just works way way better than 'quickselect' or 'selectsimilar'
In my opinion a tool like this should be available out-of-the-box. I asked the developer to make it available for BricsCAD.
Screenshot coming from AutoCAD
How do you filter for Z values? I do not see this option in 2nd image.
0 -
You're right Roy, it can't filter on a single Z value.
Just delta Z and the begin - and endpoint.
However, i find it of great value for the volume and area property.0 -
whose the developer? I can tell them how to port to bcad if needed, done it for our entire civil3d replacement program.
0 -
Well, the good news is that A>V>C did develop 'select same' for BricsCAD.
Thnik he had some difficulties putting it together and testers are wanted0 -
Good news Now Available via the official site. I use this on a daily, hourly basis..
https://www.bricsys.com/applications/a/?selectsame-a1159-al20640 -
