Import dwg or dxf file as block by "drag & drop"
Hi guys, the function "drag & drop" doesn't work well as in autocad. I mean when I drag and drop a dwg file into a bricscad, it open the file in new tab but I need to insert it as a block. Can anyone show me the right way ? Many thanks in advanced.
0
Can this tutorial help you?
https://blog.bricsys.com/tutorials/manage-blocks-drawing-explorer/
0 -
BricsCAD has a variable that controls this behavior:
Start the _Settings command and search for DRAGOPEN.0 -
Thanks for the infoS, problem solved by setting the value "0" in DRAGOPEN. Bye !
0
