XREF unload when file not found
Having trouble unloading/detaching an Xref when the file is not found. Is there a trick or is this a bug?
  • stimpy9000
    edited July 2017
    I guess i should've tested it more, as i cant seem to detach any xrefs. All of them but one have the detach option greyed out.
  • I guess i should've tested it even more...
    The one xref that didnt have the detach option greyed out somehow held all the other ones as some sort of dependencies. Once i unloaded the only one i could, some of the others became available to detach. Once i started detach those, others became available to detach. They were not nested in each other, so Im still scratching my head on it, but at least its cleaned out now.
    If you select them all simultaneously only the shared options are available.
  • If you select them all simultaneously only the shared options are available.
    i tried it both ways, selecting multiple and one at a time.
  • Still having this trouble? Maybe I can be of help
