XREF unload when file not found
Having trouble unloading/detaching an Xref when the file is not found. Is there a trick or is this a bug?
I guess i should've tested it more, as i cant seem to detach any xrefs. All of them but one have the detach option greyed out.
0 -
I guess i should've tested it even more...
The one xref that didnt have the detach option greyed out somehow held all the other ones as some sort of dependencies. Once i unloaded the only one i could, some of the others became available to detach. Once i started detach those, others became available to detach. They were not nested in each other, so Im still scratching my head on it, but at least its cleaned out now.0 -
If you select them all simultaneously only the shared options are available.
0 -
i tried it both ways, selecting multiple and one at a time.0 -
Still having this trouble? Maybe I can be of help
0
