Imac Pro and Bricscad
I was wondering how the Imac pro coming out later this year will work with Bricscad? Will it be compatible?
My Bricscad Demos ran fine so far on my nMac Pro
with Xeon, ECC RAM and ATI GPUs.
Why should the iMac Pro be any problematic ?Not sure how many operations in Bricscad can run multithreaded.
So in the end you may be faster with a cheaper consumer CPU that
has a higher single core or turbo frequency.
iMac Pros fast GPU with lots of VRAM will help displaying more complex
models on screen by OpenGL.0 -
models on screen by OpenGL.thanks!
0
