zoomed-in accuracy of points
Having had trouble getting snaps to hit the desired spot (now I think solved), I did much zooming-in to see just where an entity had actually been placed, relative to the intersection of guidelines (not GRID) where it was supposed to be.
When zoomed-in, the corner of the entity seems to jump all around the guidelines intersection. Turning off Snap, Grid, Ortho, Polar, Esnap, Strack, and visually clicking to take DISTANCE between the two, I get as much as 0.1mm apparent discrepancy, although Properties indicates it's actually spot-on.
Is that OK? 0.1mm seems a very coarse apparent discrepancy, if it's just a visual artifact. I could well be zoomed in to draw things smaller than that, but the graphics apparently cant't cope? It makes it impossible to visually check the accuracy of placements. Is there some setting?
I have the latest K2100M driver that's certified on the HP site, in my Zbook15.
Hi Tom, if you think there is a problem here please file a support request and add the drawing and all info needed to illustrate what is wrong. Our analysts will be glad to look into it.
0 -
Thanks, done that. It's also that snaps aren't finding the desired spot even though the snap marker is appearing on the spot and it's identified by tooltip. Instead, it clicks to wherever the crosshairs is within the snap aperture box.
0 -
I have a similar problem. Selecting 2D Wireframe as shown in the attached image fixed the problem in my case. A support request has been logged.
0 -
Tom could this be it.
https://forum.bricsys.com/discussion/29345/esnaps-unreliable#latest
Better i V17.0 -
I am on V17. Lodged a SR - Support says they can reproduce the (double) problem - have referred it to the Devs - that was 3 days ago.
0
