Problems inserting blocks
Recently upgraded to 17.2.12 Classic Edition. Use Bricscad primarily for 2D drafting. I have several drawings that have multiple blocks in them. When I go to insert a embedded block, I choose one form the pull down dialog box and get the "BricsCAD is unable to complete this operation." error.
Does anybody have a clue what is going on here?
Dear Mr. Harbottle, can you file a support request and add a drawing you are having this issue with? Our analysts will be glad to investigate the problem.
0 -
I have had this occasionally as well. Version 17.2.12 64 bit Pro. I suspect it may have to do with blocks that have been recently created or copied into the open drawing.
If I save the file, close it and reopen it, it seems to work again. Also you might try restarting BricsCAD.
0 -
Also, I noticed that when I get this error from the insert dialog box, that sometimes I can still insert blocks from the explorer window by right clicking on them.
0
