Fullscreen
Hi there fellows, is there a way to make brics go fullscreen with only command prompt appearing?
Thanks
Best regards,
Samuel
0
In the upcoming V18 release the CleanScreen command is introduced. This command allows to toggle the various components of the user interface on/off. In older versions you need to create a user profile in which the user interface items you do not want to see are switched off.
0 -
That's great! Thank you for your answer.
0
