Multiple print from Model space
Dear All,
I am beginner in Bricsys , before i use autocad.
In autocad we have tool for multiple print to A4 Size from drawing in model space which automatice defined by layer , but these program only run in 32 bit.
Is there any tool or way to do same thing in bricsys?
I attached sample of drawing in model space, just only few drawing. actually we have more than 50 drawing in model space.
let me know if anyone can give suggestion in here.
Regards,
Yudi
  • Louis_Verdonck
    edited December 2017
    To print multiple prints from model space do the following:
    • Create a Saved View for each of the areas you want to print.
    • In the Print dialog: choose View under Plot Area, then select the saved views in the select button.
  • how to print all at once?
    my problem is to print all with shorter time.
    thx
  • You can print multiple layouts from the same or different drawings using the Publish command. To print multiple model space views in one go you might need some Lisp tool. There is no built-in procedure for mutliple model space printing. After all, model space is not meant for printing, that's what paperspace layouts are for.
  • Additionally : Automatic search and batch printing multiple formats in model space
    https://www.kdmsoft.net/revers.html
