Using "Insert" in Menu/Lisp with Strcat
I have a menu that I use in AutoCAD for a client that uses lisp to call for blocks.
It uses a variable g_path which is set to C:/Users/cnelson/BCADStuff/ACADWIN/" then when the blocks are picked it does a strcat g_path "FORMAT/INSERT/STICKERS/506"
It does a -insert with that strcat but Bricscad errors and says block name invalid, see attached screen shot. Does Bricscad allow insert to use a variable for the block name?
Thanks!
It might depend on TEXTEVAL, but better to just strcat everything:
(command (strcat "_-INSERT " g_path "FORMAT/INSERT/STICKERS/506" "\n"))0 -
- Another Example: I am able at the command line set AA to the concatenation of g_path and the string, but in the menu it doesn't work... grrr
(SETQ AA (strcat g_path "FORMAT/INSERT/STICKERS/506"))
"C:/Users/cnelson/BCADStuff/ACADWIN/FORMAT/INSERT/STICKERS/506"
: - (la_test "NOTES" "3" "")
- -insert
? to list blocks in drawing/~ to open the file dialog/: (strcat g_path "FORMAT/INSERT/STICKERS/506")Block name is invalid. Please use =.
0 -
2 potential reasons :
a) does the path "g_path" ends with "\" or "/" ?
b) you might append ".dwg" to the filename ... maybe this fixes the "-insert" behaviour ?many greetings !
0 -
It ends in a "/" "C:/Users/cnelson/BCADStuff/ACADWIN/"
Tried the .dwg but no dice...
Thanks!
Carl
a) does the path "g_path" ends with "\" or "/" ?b) you might append ".dwg" to the filename ... maybe this fixes the "-insert" behaviour ?
many greetings !
0 -
@carlnelson:
If you are using not using (command ...) then looking at the TEXTEVAL setting (as suggested by Owen) may make sense. If you are using (command ...) post your code.FWIW: This work fine (irrespective of the TEXTEVAL setting):
(command "_.-insert" (strcat "te" "st"))0 -
It's menu driven, so what is running is:
***POP11
[SETUP]
[->Borders]
[&D-Size]^C^C(la_test "BORDER" "7" "") -insert;(strcat g_path "FORMAT/BORDER/B_D");0,0;(getvar "dimscale");;;
It's a rather large Insert block menu so I'd rather not have to re-write as it works fine in ACAD.... but I I guess a find and replace would make short work of it....
I'm just surprised that if I type -insert at the command line and at the prompt type (strcat g_path "FORMAT/BORDER/B_D") it says block name is invalid....Carl
@Roy Klein Gebbinck said:
@carlnelson:
Thanks Owen!
I set TEXTEVAL to 1 and it works great! Whew!
Doh!Thank you everyone for helping out!!!
Carl
Additional, if you check
textevalin AutoCAD you will probably notice it is set there to1too (default is0), behaviour of both programs is quite similar when doing basic things like-insert. Owen and Roy suggested a more structural solution for the future ;-)0 -
@Wiebe van der Worp said:
Additional, if you checktextevalin AutoCAD you will probably notice it is set there to1too (default is0), behaviour of both programs is quite similar when doing basic things like-insert. Owen and Roy suggested a more structural solution for the future ;-)Thanks!
TEXTEVAL when I checked in AutoCAD was set to zero, which is why I never thought to check that... lol
This client 3rd party menu that I have to use was created in the 1990 and earlier, the last update was for AutoCAD 2011 on 4/4/2013, it's really creaky and I am thrilled that less than a week after downloading BricsCAD it now works flawlessly! :-) happy dance!
Carl0
