Has anyone had luck installing BC17.2.14 on KDE Fedora 27 ?---This was answered
Rodolphe Simon
edited February 2018 in Linux
Has anyone had luck installing BC on Fedora 27 ? I'm getting a dependency issue on dnfdragora pkg installer: ['\n Problem: conflicting requests\n - nothing provides libpth.so.20()(64bit) needed by bricscadv17-17.2.14-1.x86_64'].
There is no such "libpth.so.20" file in usr/lib64 for FC27 anymore. Older versions of Fedora did have this lib file.
Could this be that FC27 is too new and I need to wait for BC18?
  • Rodolphe Simon
    Answered by tech support. They will provide a libpth patch to install prior to installing the Bricscad rpm. It's really not a big deal and it takes less than 2 minutes. BTW tech support did a great job with answering this issue.
