Customizing settings
I couldnt find this in any threads so here it is.
First, I have been trying to find where to change the color of the osnap (esnap I think in BCAD) grip. The default is red and want to change them to yellow. I managed to change others in the settings tab but no luck with the snap.
The other big thing is that solids are opaque. I can't see through boxes, extruded objects etc. I dont want to change each individual object manually. I want them to be transparent wireframes from the get go.
I may have more questions. I still havent set up my toolbars, which is two pages worth of commands that I have to hunt down.
Thanks,
AB
Hi Castrosua
Have you tried this? (see img)
Combined with "view render modes" it might be what your looking for.
Several different transparency levels in this one.
0 -
There is a search field in the _Settings dialog. Look for 'snap' and you will find: 'SnapMarkerColor'.
0
